Sep 18th, 2024, 12:59am
SSCG's spec for EMI reduction (Read 3313 times)
Monkeybad
Apr 23rd, 2008, 7:36pm
Hello, everybody!
Has anyone designed the spread spectrum clock?
My company's product is suffering the EMI problem. I need to redesign a PLL which has a spread spectrum function. I use a fractional-N PLL to implement it. A 40kHz triangular wave is applied to the VCO's controlling voltage. A MASH1-1-1 sigma-delta modulator is used.
My question is how much attenuation in the spectrum for the EMI reduction is enough?
Can anyone give me some suggestions? Where can I find the detailed specifications?
taofeng
Belgium
Re: SSCG's spec for EMI reduction
Reply #1 - Apr 27th, 2008, 4:30am
You normally should get this from your customer.
As far as I know, 5-7 dB reduction is more than enough !
Monkeybad
Reply #2 - Apr 27th, 2008, 7:59pm
Thanks for your reply! taofeng!
I'll try to contact the manufacturer to get the information.
In my result of simulation, I can get about 20dbm attenuation at maximum modulation.
So it seems quite enough!
taofeng
Belgium
Reply #3 - Apr 28th, 2008, 1:57am
It also depends on the interesting range of the frequency. Although you could get 20dB attenuation, it not necessary to say your product will
pass the test if the frequency with maximum attenuation is not the critical one or beyond the range of interest. Also ssc technique is only effective
for radiated emission , for conducted  emission it is an another story.
Watch out the timing margin of your system under the maximum spread ratio. Normally it is within +-2%.
