weber8722
Hi, I read the great paper, but wonder a bit on p.45 showing the Matlab script for phase-noise vs f. Basically you need to do a psd calculation on the cumulated phase, which is in the example basically a huge vector (2GHz * 60ms), starting with something like 0,6.28...,12.5....,.... However, why the psd takes only 512 samples from this huge vector? The maximum frequency should be 1/60ms*512 = 8.5kHz, which does not fit to the graphs. A second also important question, does anybody has this in SKILL for Cadence ADE calculator - or just directly the calculator expression?
Bye Stephan
