Aug 16th, 2024, 4:24am
High frequency switch - 2N4391 (Read 411 times)
liveavr
Apr 26th, 2008, 12:41am
This circuit uses a 2N4391 JFET to create a high frequency switch. The 2N4391 JFET provides a low on-resistance of 30 ohms and a high off-impedence (<0.2pF) when off. Other specs are: attenuation > 80dB @ 100MHz and insertion loss approximately 6dB. With proper layout and an "ideal" switch, the performance stated above can be readily achieved.
