Jul 19th, 2024, 6:23am
calculate the input  impedance  for cmos (Read 3555 times)
wwm101
china
May 01st, 2008, 7:45am
why the follow circuit diagram which input impedance equal to 1/(gm1a+gm1b) in the radio frequency?
this problem confuse me long time .pleas help!
thank you for your attention!
View Profile wwm101 weiming022002@yahoo.com   IP Logged
Re: calculate the input  impedance  for cmos
Reply #1 - May 1st, 2008, 9:30am
wwm101 wrote on May 1st, 2008, 7:45am:
If it is not in the radio frequency, it is very simple.
Transconductance of inverter is Gm=gm1a+gm1b.
So input admittance Yin seeing right at node X is like following.
Yin=GF*(YL+Gm)/(YL+GF)
where GF is feedback conductance for self bias, so GF=1/R, R is resistor between X and Y.
YL is load admittance at node Y.
If ZL=1/YL=infinity, Yin=Gm=gm1a+gm1b.
If ZL=1/YL=0, Yin=GF=1/R.
If GF=0, Yin=0.
So if impedance seeing right at node Y is enough high, ZL >> 1/Gm, 1/GF=R
an input impedance Zin seeing right at node X will be 1/Gm=1/(gm1a+gm1b).
For the radio frequency, this is not true.
« Last Edit: May 2nd, 2008, 1:46am by pancho_hideboo »
wwm101
china
Reply #2 - May 2nd, 2008, 12:37am
TO:pancho_hideboo
thank you very much for your explain.
