Aug 15th, 2024, 10:25pm
Common-mode point for OPamp (Read 1903 times)
nxing
God help the person
who help themselves
China
May 01st, 2008, 12:07pm
Hello everyone,
I have a question regarding how to setup the output common-mode voltage before connect the CMFB circuit. Should these points be close to what ever we want (for example, vdd/2) or it doesn't matter as long as the we can correct them with CMFB circuit?
Thanks!
Norman
HdrChopper
Re: Common-mode point for OPamp
Reply #1 - May 1st, 2008, 2:24pm
Hi Noman,
The CM voltage should be selected in order to guarantee the required differential signal excursion. Then the CMFB will be the one forcing such CM level and will obviously have to be designed for working at those levels.
Tosei
Keep it simple
