Aug 15th, 2024, 6:43pm
questions about  SHA (Read 6661 times)
icguy
Seoul Korea
questions about  SHA
May 04th, 2008, 8:13am
In my Project, A 10 bits 100MHz Sample and hold amplifier  need to be done; I just don't  know how to figure out the DC Gain ,Unity Gain BandWidth of the OTA ,   anybody konow sth about this ?  tks!
The trouble with random processes is that they are random
bananawolf
Re: questions about  SHA
Reply #1 - May 4th, 2008, 12:40pm
My initial guess is the opamp DC gain>70dB and the SHA should have a closed-loop bandwidth>350MHz.
HdrChopper
Reply #2 - May 4th, 2008, 4:15pm
The loop gain has to be at least 60dB in order to fulfill the 10 bit resolution requirement. Therefore, the opamp DC gain has to be larger than 60dB: as large as the (DC) closed loop gain + 60dB at least.
Concerning the BW, it is important to guarantee the holding caps get the final value within the sampling time. Thus, both the RC associated to the sampling circuit and the amplifier have to be much faster than the sampling time: actually 99.999% of the final value has to be guaranteed in order to meet the 10 bit resolution. From this number you can derive the number of time constants fitting in the sampling period and afterwards the bandwidth for both circuits.
Hope this helps
Tosei
Keep it simple
icguy
Seoul Korea
Reply #3 - May 4th, 2008, 7:19pm
Tosei  Tks for your reply
should the DC Gain be calculated as follow ?     DC Gain > 20log10(2^10)+20log(1/f)  f=feedback factor
I can Understand Rc Associated to the sample circuits, it is  a Transistor-on resistance and sampling capacitance;Yet Ican't
understand RC of the amplifier you mentioned above . In addition, why the settling time accuracy is 99.999%(or 0.001%),some papers
just take 0.1% or 0.01%, Can the  settling accuracy arbitrarily  chosen? I am totally confused.
Reply #4 - May 5th, 2008, 8:15am
ICguy,
  You may wish to add more margin to the DC gain calculation, usually
you try to keep the systematic errors small, ~0.25lsb or less. Since you
have assumed that the settling is purely due to RC-settling, it is not
unreasonable to include additional margin. The other option would be
to include the effect of slew rate in the settling time calculation.
HdrChopper
Reply #5 - May 5th, 2008, 6:35pm
icguy wrote on May 4th, 2008, 7:19pm:
Yes, that would be the min acceptable value for your amp gain.
[/quote]
just take 0.1% or 0.01%, Can the settling accuracy arbitrarily  chosen? I am totally confused. [/quote]
From the small signal perspective, if the opamp had a BW much smaller than the RC time constant, it might not be able to respond fast enough in order to force the desired voltage across the sampling cap, simply because it could not provide enough current to it. Therefore the amp BW should be such that a fair number of time constants (9 may be) fit within the sampling time.
Sheldon also brought up a good point about slew rate, which is a large signal condition that your opamp will have to meet, apart from the ones mentioned above.
Hope this is a little bit more clear.
Tosei
Keep it simple
Berti
Reply #6 - May 5th, 2008, 10:24pm
Just an additional comment on DC-gain:
OpAmp non-linearity will cause distortion. Therefore, OpAmp gain often has to be larger
to keep the harmonics small enough.
Cheers
icguy
Seoul Korea
Reply #7 - May 7th, 2008, 7:18am
To get some intuitive understanding ,I first designed an opamp with 240MHz Gain Band Width and 78 degree Phase Margin and 85dB DC gain ;
My opamp consists two stage, the first stage is telescopic and the secong stage is a commom source output;
step response is simulated  in Spectre. the attachment is the  simulation result. from the figure we can see that slewing period is comparable to
the settling period. do i have to do sth to supress the slewing period? or leave it alone and  just to  improve the opamp'GBW to get a better
settling ?
tks again
Berti
Reply #8 - May 7th, 2008, 10:32pm
To me this settling curve doesn't look so nice because of the ringing. I think you have to be careful when using two-stage
amplifiers because the pole-zero doublet from the Miller compensation can cause ringing in the step response.
Cheers
