hpham100
Hi, I am designing a limiting amplifier, and tried to simulate jitter using pnoise analysis. My set up is like this: --beat frequency : 4G --output amplitude 400mVp-p (differential) --input amplitude : from 2mV-400mVp-p (differential) (ideal sine wave from psin) --pnoise setting : sweeptype = absolute, noisetype=jitter,threshold value=0, crossing direction=all, sweep from 1G->10G Jitter(Jcc) results : 1) vin=2mV --> Jcc[Second][k=1]@(3G,5G)Hz:rms = 18p 2) vin=4mV --> 9.05p 3) vin=200mV --> 0.263p 4) vin=400mV --> 0.191p So, jitter results seems to be strongly dependent on input amplitude ?? Is it right ?? I also run transient analysis with different input amplitude(from 2mV-->400mV), and check phase variation of output voltage(zero crossing) -- on rising edge : delta ~ 2.75ps -- on falling edge : delta ~ 0.91ps (Input Freq is 4GHz) I am not sure about the relationship between jitter number using pnoise analysis and AM->PM number using transient analysis as above? Could someone help me to clarify this. Thanks alot. ha P.S: when running pnoise analysis from 1G to 10GHz, in the output log window I saw pnoise sweeping from 1G --> 10G TWICE !! Why is that??
