Aug 15th, 2024, 9:28pm
current limiter in Verilog-A (Read 1325 times)
icdes321
May 25th, 2008, 4:02am
I am writing a current limiter in Verilog-A. Should be simple but in simulation the results are not as expected. Any suggestions will be appreciated.
`include "discipline.h"
`include "constants.h"
module current_limiter(in,out);
inout in, out;
current in,out;
parameter imax = 100e-3;
analog
begin
  @(initial_step)  if (I(in,out) > imax) I(in,out) <+ imax;
Thanks.
Stefan
Re: current limiter in Verilog-A
Reply #1 - May 25th, 2008, 5:08am
@(initial step) makes the simulator evaluate the next statement only once at the beginning of the simulation.
Your limiter simply does nothing for the rest of the simulation time.
View Profile 16731287   IP Logged
icdes321
Reply #2 - May 25th, 2008, 6:18am
Stefan, Thank you. But adding "if (I(in,out) > imax) I(in,out) <+ imax; " does also not work.
inout in, out;
current in,out;
analog
begin
Reply #3 - May 27th, 2008, 5:30am
Yikes!  I don't think you've got the idea here at all.  What about:
inout in, out;
current in,out;
real iout;
analog
begin
 iout = I(in);
 if (iout > imax) iout = imax;
 I(out) <+ iout;
Reply #4 - May 27th, 2008, 11:54am
The problem is more subtle than that. To build a reliable current limiter you cannot simply compare the output current against Imax, and then if above Imax, set the output current to Imax. Once you override the output current, it is no longer over Imax. This results in the state switching back and forth between limiting and not limiting on every iteration, which would cause convergence problems. A robust model can be found in the Verilog-AMS section of this site (www.verilog-ams.com). It is called "Current limited voltage regulator" and can be found in the functional Verilog-A models section.
