Jul 19th, 2024, 2:42am
calculated the noise factor of 2-most amp (Read 4452 times)
wwm101
china
May 26th, 2008, 6:38am
in Federio Bruccoleri doctor degree’s paper
he assumes the MOST only have drain noise (channel noise)
then definitely the drain noise I2n/△f=4KT*r*gm=4KT*NEF*gm
in follow schematic, he calculated the noise factor equal to 1+NEFa+4NEF(AVF-1)/AVF2   at ΔNEF=NEFb-NEFa And gb+1/ZL>>0(gb+1/ZL=gb) 。
how to calculate it by hand?
Thank you in advance!
View Profile wwm101 weiming022002@yahoo.com   IP Logged
Re: calculated the noise factor of 2-most amp
Reply #1 - May 26th, 2008, 5:18pm
wwm101 wrote on May 26th, 2008, 6:38am:
In the above, "r" is equal to "NEF" ?. And this is typically 2/3 ?
In the above, what do you mean by "NEF" in "4NEF" ? What is AVF ?
What do you mean by "0(gb+1/ZL=gb)" ?
Maybe a topology you refer is "Amp-1" in the following.
Quote:
You can derive Noise Factor equation easily if you trace all formulations and equations in the above.
You have more detail documentation(PhD dissertation), don't you ?
« Last Edit: May 26th, 2008, 8:47pm by pancho_hideboo »
wwm101
china
Reply #2 - May 27th, 2008, 6:04am
TO:pancho_hideboo
thank you very much for your attention。
i'm very  sorry for my ague expression and clerical error
correct:
first ,in drain noise‘s  expression ,the drain noise must defined as I2n/△f=4KT*r*gd0=4KT*NEF*gm,where gd0  is the channel conductance for VDS=0 and r is a bias-dependent parameter.For a long-channel MOS in saturation,r=2/3 and gd0=gm holds.For a deep sub-micron mosfet,r>2/3 and gd0>gm arise from the large electric field along the channel.  NEF is  short for "noise excess factor" ,NEF= r*(gd0/gm)>r ,introduced to quanify the excess of noise current with respect to a resistor R=1/gm .
second, the noise factor of 3most amplify is equal to 1+NEFa+4*ΔNEF*(AVF-1)/AVF2 . where ΔNEF=NEFb-NEFa  , gb+1/ZL>>0 (in the other way gb+1/ZL≈gb) and AVF is the voltage gain of amplifier.
« Last Edit: May 28th, 2008, 1:07am by wwm101 »
wwm101
china
Reply #3 - May 28th, 2008, 6:44am
TO:pancho_hideboo
i have readed the paper you introduce。but i can't derivate the expression. how to derivate  in detail?
thank you in advance!
Reply #4 - May 31st, 2008, 5:46am
wwm101 wrote on May 28th, 2008, 6:44am:
Do you truely trace equations ?
Show me your incomplete formulations to derive NF.
http://www.designers-guide.org/Forum/YaBB.pl?num=1209653115
You couldn't derive the above by yourself although it is very easy to derive.
This is a simple exercise level in school.
« Last Edit: May 31st, 2008, 8:16am by pancho_hideboo »
wwm101
china
Reply #5 - May 31st, 2008, 9:29pm
thank you very much ,i have derivated it Grin
