Jul 19th, 2024, 10:27am
divide  by 2.5 (Read 2064 times)
nxing
God help the person
who help themselves
China
divide  by 2.5
May 27th, 2008, 2:45pm
I need to design a divider to divide the signal by 2.5 ( the input signals are at around 4GHz), I would prefer the injection lock divider. Does anybody have any idea how to design that? or can refer to any papers regarding this matter?
Norman
Zero
Re: divide  by 2.5
Reply #1 - May 30th, 2008, 4:16am
As far as I know, the injection locked dividers operate as integer dividers (you simply synchronize the nth harmonic of the oscillator to the input signal). However, to make such fractional divider, ÷2.5, you can multiply by 2, then divide by 5; one way to do that is to make a divide by 5 using flip-flops working on both clock edges. That would be possible at the GHz range if you are using a fast process. The alternative might be using an injection locked multiply-by-2 followed by an injection locked divide-by-5!
