Jul 19th, 2024, 8:34am
pad layers (Read 2363 times)
aaron_do
pad layers
May 29th, 2008, 10:53pm
just wondering, how many metal layers do we normally have under the pad layer for an RF or digital pad?
thanks,
Aaron
vivarf
Re: pad layers
Reply #1 - May 30th, 2008, 3:55am
I get the pad from the seniors' design which contain all the metal from bottom to the top.
However I did not get any explanation so I also need some advices.
View Profile veeater   IP Logged
bernd
Munich/Germany
Re: pad layers
Reply #2 - May 30th, 2008, 4:58am
We have
- RF pad top metal to top metal -2
- Digital pad top metal to bottom metal
Bernd
Just another lonesome cad guy
ACWWong
Oxford, UK
Re: pad layers
Reply #3 - May 30th, 2008, 6:25am
As bernd indicates, the details depends on your foundry.
But RF pads benefit from being top metal only if it is mechanically robust enough for the bonding process. I have used technology where this was allowed... others where it is not.
I have also seen a trend for circuitry (mostly ESD or IO drivers) to be incorporated beneath pads, in which case the metal layers which constitute the pads are the higher levels only.
