Sep 26th, 2026, 11:41am
Pages: 1 2
how to predict oscillator's start-up time? (Read 20629 times)
sapphire
Re: how to predict oscillator's start-up time?
Reply #15 - Jun 06th, 2008, 9:32am
Hi Hyvonen
Thanks for your detailed explanation. I have one comments about your reply. You said that higher Q means faster transient. Is that true? Higher Q is good for better phase noise at steady state. But higher Q also means larger time constant, which translates into longer transient period into steady-state. That's also the reason whey crystal oscillator is difficult to simulate as mentioned in the AN buddypoor referred.
Hyvonen
Reply #16 - Jun 6th, 2008, 9:00pm
Hi Sapphire,
Yes; it's true that having a higher Q means faster oscillation ramp-up (if everything else is equal).  This can be analyzed in many different ways, but here's how I do it:
Oscillator tank actually consists of a parallel network of L, C, Rtank and Rneg.  Rtank represents the tank Q - the higher the tank Q, the higher Rtank is (approximately, Rtank=Q*wL=Q/wC for high-Q tanks).  Rneg is the "negative resistance" - the mechanism through which the active device provides energy into the tank, keeping the oscillation going.  The parallel combination of the two resistances is Rtot=Rtank||Rneg - if the parallel Rneg is smaller than Rtank, Rtot is negative (meaning the oscillation amplitude grows over time).
If you write down the differential equation for the tank and solve the transient response, you get something like:
v(t)=e^-(1/(2RtotC))*(c1cos(w0t)+c2sin(w0t))
where w0 is the oscillation frequency and c1 and c2 are constants (dependent on initial conditions).  Note that in our case, Rtot is negative (for growing oscillation amplitude), so e^-(1/(2RtotC))=e^(1/(2|Rtot|C)), indicating exponential growth in amplitude.
To make the amplitude ramp up faster, we need to increase the value of 1/(2|Rtot|C)=0.5*(1/C)*(|1/Rneg|-1/Rtank).  If the only knob we have to turn is the tank Q, increasing it is the best way to improve the ramp-up speed - in the extreme case of infinite Q, 1/Rtank=1/(QwL) approaches zero, so 0.5*(1/C)*(|1/Rneg|-1/Rtank) approaches 0.5*(1/C)*|1/Rneg|.  If Rtank is anything less than infinite, it would only reduce the value of 0.5*(1/C)*(|1/Rneg|-1/Rtank), reducing the oscillation ramp-up speed.
(Another way to improve the ramp-up is to make the value of Rneg really small while keeping it negative... that would really increase the value of 0.5*(1/C)*(|1/Rneg|-1/Rtank).  This is another unintuitive result, but it's all coming from the way negative resistances behave.)
One way to look at this is to consider the ideal case of an infinite tank Q of the RLC tank.  Here, your Rtank would be infinite (since it's connected in parallel it would be like an open circuit), and all you would have left is the L and the C.  Then, you connect a "negative R" component in parallel with it to provide some energy into the tank that gets the oscillation going.  If your tank wasn't ideal (i.e., finite Q), you would lose some of that energy in the non-idealities (parasitic resistance...).  If it is ideal (infinite Q), the negative resistance can do its job to increase the oscillation amplitude without any losses.
To me, these things are always a bit confusing - parallel resistances, series resistances... tank Q, inductor Q, capacitor Q, negative/positive resistance...  resistance/admittance...  All of it can be analyzed through math and network theory, but for quick roundabout answers, I rather go through energy: negative resistance supplies energy into the tank and positive resistance sucks it away (and converts it into heat).  The more effective the negative resistance is (the smaller the parallel negative resistance is), the faster energy is supplied into the tank, and the more "effective" the positive resistance is (the smaller the parallel positive resistance is), the faster energy is sucked away.
The explanation above is an incoherent mess.  :o  But if you have any questions, let me know, and I'll try to elaborate.
« Last Edit: Jun 7th, 2008, 10:17am by Hyvonen »
Hyvonen
Reply #17 - Jun 6th, 2008, 9:09pm
Forgot to mention two things:
1) You can rather easily verify that increasing tank Q increases the ramp-up speed in simulations.  Just make your "inductor Rser" (=inductor series resistance, used to model the inductor Q) really small, and you'll see the amplitude ramp up like mad.
2) The constants c1 and c2 in the differential equation solution are dependent on initial conditions.  This is what I was trying to point to when I said it's difficult to exactly predict the ramp-up time, since it depends on the initial condition.  If you set v(t=0)=0, you can't satisfy the initial condition unless c1&c2 are both zero (no oscillation, ever).  So, you have to have some initial energy in your system (noise...) to have non-zero c1&c2, and to get any oscillation going.  (By the way, this is partly why it's difficult to get oscillators start up in simulators... if the simulator is perfectly accurate and no noise is applied, the oscillation doesn't start up because of this very reason... you need to have an inaccurate simulator and/or initial condition for the oscillator nodes to get the oscillation going)
« Last Edit: Jun 7th, 2008, 10:15am by Hyvonen »
buddypoor
Bremen, Germany
Reply #18 - Jun 7th, 2008, 2:21am
Hyvonen wrote on Jun 6th, 2008, 9:09pm:
1) You can rather easily verify that increasing tank Q increases the ramp-up time.........
Hyvonen: There seems to be a typing error as your position is just the opposite: Q prop. to speed rather than time.
But it is to be mentioned that - as suspected by me formerly (my replies 1, 4 and 6) - it can be proven that the start-up time of oscillators is proportional to the network Q. However, it seems that this holds only for four-pole oscillators with an active feedback element.
If Hyvonen is correct in his argumentation (and I cannot argue against it) there is obviously a difference between two-pole negative-resistance and four-pole oscillator circuits - as far as the start-up time ic concerned. That seems to be a fact worth mentioning. I think it was a very interesting question not answered up to now in any textbook.
Hyvonen
Reply #19 - Jun 7th, 2008, 10:22am
Buddypoor: yes - I had a typo there; I edited the post to say "speed" instead of time.  Thanks for finding the error!  :)
I also slightly updated the equations in the main post - there were sign typos in some of the equations.  The discussion was correct, though.
I'm not familiar with four-pole oscillators.  Are crystal oscillators four-pole...?
buddypoor
Bremen, Germany
Reply #20 - Jun 8th, 2008, 12:50am
Hyvonen wrote on Jun 7th, 2008, 10:22am:
Four-pole oscillators consist of a frequency selective network (bandpass, lowpass, highpass, notch, crystal) and an amplifier, all connected in a closed loop to produce a loop gain Aloop=1 (Barkhausen condition).
The well known WIEN oscillator belongs to this group.
sapphire
Reply #21 - Jun 10th, 2008, 12:01pm
Hi Hyvonen,
Thank you very much for the elaboration. I need some time to understand. Would you please tell a little more about how the damping voltage equation is derived?  I think we are more close to the final goal - derive an analytical model to predict the turn-on time.
Sapphire
Hyvonen wrote on Jun 6th, 2008, 9:00pm:
Hi Sapphire,
Hyvonen
Reply #22 - Jun 10th, 2008, 2:33pm
You can set up a differential equation for the parallel LRC circuit (where R=Rneg||Rtank) by using Kirchoff's current law:
ic(t)+ir(t)+il(t)=0
<=> C∂v(t)/∂t+1/R*v(t)+1/L∫v(t)∂t=0
<=> C*D^2+1/R*D+1/L=0 (where D=∂v(t)/∂t)
You can solve this second-order equation (see
http://www.analyzemath.com/calculus/Differential_Equations/solve_second_order_3.... for help), with the assumption that the voltage response is oscillatory (i.e., second order solution is a complex pair).  This yields the result
v(t)=e^-(t/(2RtotC))*(c1cos(w0t)+c2sin(w0t))    (note that I forgot the "t" from the original equation - that was a typo)
Now, we should be able to determine one of the two constants by defining the initial voltage at t=0 to be something (some amount of noise); that would give us c1 (sin0=0).  I'm not sure how to obtain the second constant, though... if anyone has a suggestion, that would be great! Smiley
sapphire
Reply #23 - Jun 10th, 2008, 8:39pm
Thanks for the reply. I have derived the transient voltage using inverse fourier transform by abstracting the differential pair as a negative resistance and absobing it into the RLC tank. It has exactly the same format as the one you gives! What I also find is that the constant C1and C2 is related to each other. So if we know the initial damping voltage, we can determine C1 and C2 together.
Based on the equation, I think your comment about Q is correct.
There are still two questions needed to be addressed in order to give a closed-form analytical solution.
1. how to determine the initial damping voltage. If the oscillator is just kept running in steady-state, then this analysis is not meaningful. If the osicllator is turned on/off and used as an OOK modulator, then the analysis is helpful. Supposed the oscillator is suddenly powered on, what's the initial damping voltage and how to determine it?
2. As the osicllator goes from small-signal to steady-state, the negative-resistance is also changing non-linearly. That means the function has a time-varying parameters. How to represent this change into the equation and/or give a approximately accurate result?
Hi buddypoor,  what's the differenence between 2-port oscillator and 4-port oscillator?  Is the common differential LC VCO 2-port or 4-port oscillator?
Thanks for all the discussion!
Hyvonen wrote on Jun 10th, 2008, 2:33pm:
ic(t)+ir(t)+il(t)=0
Hyvonen
Reply #24 - Jun 11th, 2008, 1:30pm
Sapphire,
1.  By 'initial damping voltage', do you mean the tank voltage at t=0 (initial condition)?  The word 'damping' confused me. Smiley  Initial voltage is undefined, but the oscillator will start up due to noise in the circuit - the exact ramp time is hard to predict, though.  A couple of posts ago I suggested providing a well-defined initial voltage (e.g., charging up the tank capacitor to some voltage before turning on the diff. pair); this would give you an initial voltage to start from and the ramp would be possible to calculate.
2.  This is true; the negative-R value will get larger until the oscillation amplitude doesn't increase anymore; this is much harder to analyze.  You'd need to analyze this using nonlinear differential equations (as opposed to the simple linear differential equation I used), and I cannot help you there.  What is it that you're aiming to solve?  The time it takes for the oscillator to reach a certain oscillation amplitude?
sapphire
Reply #25 - Jun 12th, 2008, 11:08am
"initial damping voltage" is referred to the voltage amplitude of first cycle when oscillator is powered on. So it may also depends on how fast the power supply is turned on. The oscillator is not starting up from noise voltage, but from the initial damping voltage. This is kind of initial condition. Your suggestion is valuable, and I can try to relate the bias current and tank characteristic with the initial damping voltage.
In this scenarioes, I guess the transient voltage function only contains sin(wt) term, which means C1 is zero. Because the process can be modelled as a step input or 1/s in laplace domain.  How do you think?
For the nonlinear negative resistance, yes, it's very hard to represent it in the linear equation. My goal is to find an approximate expression to model the turn-on time: the time from power on to steady-state oscillation. Hopefully it can help understand the transient process and guide the design a little bit. I am trying to talk some math people to see if there is some simple analytical solution to nonlinear differential equation.
Hyvonen wrote on Jun 11th, 2008, 1:30pm:
Sapphire,
buddypoor
Bremen, Germany
Reply #26 - Jun 12th, 2008, 11:33pm
[quote author=sapphire link=1212177977/15#23 date=1213159181]T
[quote author=Hyvonen link=1212177977/15#22 date=1213137185]
Watch your typo: Not 2-port and 4-port, but instead 2-pole resp. 4-pole topology.
Pages: 1 2
