Aug 15th, 2024, 6:18pm
headroom simulation (Read 2821 times)
skas20
headroom simulation
Jun 06th, 2008, 2:27am
Can somebody please explain me fundamentally what is headroom simulation in analog circuits?
- I can understand its a simulations to make sure that all transistors are having enough vds to remain in sat.region even with a slight supply voltage changes..
- what I want to know is what are the methods to understand whether a transistor has enough headroom?
- do we have to run the simulation in all the corners etc...
Thanks.
AnalogDE
Re: headroom simulation
Reply #1 - Jun 10th, 2008, 12:10am
You want to check to see that your Vds > Vdsat (for short channel transistors you want to look at the Vdsat given by SPICE, it's not equal to Vgs-Vt).
The worst case corner for headroom is
low VDD
slow corner (slow corner => transistors weaker => higher Vdsat req'd to keep in saturation)
highest temperature (high temp => lower mobility => higher Vdsat req'd)
and w/ transistors operating at their highest current levels (higher current => more Vdsat).
weber8722
Reply #2 - Mar 17th, 2009, 7:25am
AnalogDE wrote on Jun 10th, 2008, 12:10am:
low VDD
Let me add:
Slow corner for transistors!!
But fast corner for resistors!!
Wether high or low temperature corner is worst-case depends on current densitity. For low current usually the lowT corner is much more critical.
Bye Stephan
