Aug 15th, 2024, 8:15pm
Build ideal fully differential amplifier using vcvs (Read 8372 times)
seahs
Mar 09th, 2009, 7:13am
I saw this one on jacob's circuit design, layout and simulation(pg 841). It is using spice.
While I implemented it in sprectre. It always showed vcvs had shorted output( as shown in the graph). I simulated it anway and it didn't work.
does anybody know what  the problem is?
raja.cedt
Re: Build ideal fully differential amplifier using vcvs
Reply #1 - Mar 9th, 2009, 8:16am
hi,
   i don't know about cadence,but i think the problem is you have not specified the  common mode voltage(you have to put separate common mode voltage source).
Rajasekhar.
boe
Reply #2 - Mar 9th, 2009, 8:26am
Seahs,
in your schematic, both sources connect to the same nets (according to net names shown); I suggest you remove net vcm and redraw it.
BOE
seahs
Reply #3 - Mar 9th, 2009, 10:08am
raja.cedt wrote on Mar 9th, 2009, 8:16am:
hi,
Rajasekhar.
Thanks for your reply. Actually I had already specified common node voltage.
I also tried seperating them but it did not work. I think it is not a problem whether to seperate them or not. As I saw they are connected together in the jacob text book in spice.
seahs
Reply #4 - Mar 9th, 2009, 10:48am
I changed the vcvs_ahdl from andlLib to vcvs from analogLib, the error message disappeared. But this vcvs has lots of parameters to fill. I filled some of them and it seems still not work.
Reply #5 - Mar 9th, 2009, 2:54pm
The key problem is (as was said earlier) that it appears that both of the vcvs are connected between vout_p and vout_n . It's not obvious from the schematic snippet why that is. Perhaps you could upload a simple (small) database in (say) tar.gz format with that part of the circuit, so one of us could take a look.
I don't think you need to specify a delay on vcvs - the gain should be sufficient.
Reply #6 - Mar 11th, 2009, 12:24pm
Are vout_p and vout_n netnames, or the pin names of the vcvs?
holddreams
Reply #7 - Mar 17th, 2009, 8:26am
Have you simulated the circuits successfully?
You can try the VCVS in the attatchment.
