Eugene
An current controlled source has to be told what current controls it. You do that by inserting a vdc with zero volts in series with the current you want to sense. Then when you insert the controlled source, you point it to the zero volt vdc. The thing to watch out for is when you cut and paste the combination, the reference designator of the vdc will change and you have to remember to point the controlled source to the new current probe.
