Oct 19th, 2024, 4:20pm
want suggestion on low delay comparator design (Read 3639 times)
manodipan
Jun 09th, 2008, 9:06am
Hi Guys,
I am facing some problem in comparator design.I want a (1-2)ns and low slew(<300ps) comparator.For that purpose i have designed one cascaded differential amplifier(first 3 stages) connected to a level converter and then final inverter.Supply is 1.2V and 0.13um process.The delay and slew i get for this is 3.2 ns and very large slew(~1ns).Each differential amplifier consumes around 20uA.So can u suggest some better solution for my design.Does a preamplifier help in this case??pls reply soon...
Berti
Re: want suggestion on low delay comparator design
Reply #1 - Jun 9th, 2008, 10:11pm
What do you mean with "slew"?
manodipan
Reply #2 - Jun 9th, 2008, 11:07pm
Here slew means the output changesfrom logic lo to hi or hi to lo in that time .So essentially output takes that much time to change from one logic to other..traditionally it os defined as time to reach from 10% to 90% of the signal.
AnalogDE
Reply #3 - Jun 10th, 2008, 12:03am
You want to have enough bias current to meet your slew rate requirement.  Use minimum or near minimum length and use a low gain topology...
manodipan
Reply #4 - Jun 10th, 2008, 10:40pm
Hi Jiesteve,
Lot of thanks for ur help,my circuit has worked.But i have some questions:i have used minimum length devices,and for low gain topology i have used higher overdrive devices(Vdsat),so it increases the current without changing the size,thus improve the speed.But menwhile the power is consumed ,how to minimise the power consumption in this case??
AnalogDE
Reply #5 - Jun 11th, 2008, 9:48pm
It's hard to tell you without looking at your circuit.  Assuming your load is fixed and you have enough bias current flowing to meet your slew rate requirement then to save power you generally need to make device sizes smaller, at the cost of increased mismatch (offset), reduced swing and what not...
