Jul 18th, 2024, 12:32am
How to design current source for RF circuits?? (Read 162 times)
zhangjerome
Jun 11th, 2008, 8:13pm
Generally we use long channel devices to design current sources in low frequency circuits. Long channel device leads
to large parasitics, which can be significant in RF application. Is there any rule of thumb for current source design??
Thank you.
vivkr
Re: How to design current source for RF circuits??
Reply #1 - Jun 12th, 2008, 3:24am
which parasitics are we talking about?
Gate-drain cap (CGD) is mostly overlap cap and thus independent of L.
Gate-source cap (CGS) should not matter as it will only load the bias reference levels from a diode connected transistor.
Longer L will actually give you a good current source and better PSRR, well not at RF though Smiley
Vivek
Hyvonen
Reply #2 - Jun 12th, 2008, 8:40am
Zhangjerome: Do you mean that long-channel device leads to high parasitics because you have to increase also the width to get the same W/L (or overdrive for a given current)?
You will have to just take the hit in either Rout or parasitics... or, if you have headroom, you could consider using a cascode.  And Vivek makes a good point - at what frequency do you want your PSRR to be high (and how high)?
zhangjerome
Reply #3 - Jun 14th, 2008, 1:27am
Yeah, that's what I mean. Both W and L have to be increased if long channel devices are used to implement the current source with constant current.
It's not only the PSRR. Small output impedance and large parasitic cap both lead to RF signal leakge  if  the current source is used as  load.
Hyvonen
Reply #4 - Jun 14th, 2008, 1:16pm
I assume you don't need to match the output impedance to 50ohms etc.
If your amplifier is narrow-band, maybe an LC tank could do the job.  If it's broadband, then maybe you could use an actual physical resistor as a load...?  Or are you really shooting for a maximum possible gain (like in an opamp), while maximizing gain?  I think I would look into a cascode in that case.
Reply #5 - Jun 16th, 2008, 12:34pm
One other thing - Current sources are noisy! A lot of engineers design RF systems using current sources and active load structures --- until --- they look at the noise performance! Then, things get redesigned into resistors, or LC methods.
Also, don't obsesses on keeping the currents perfect and put cascodes everywhere. In most cases the current can vary some and you dont need the cascode. More headroom, fewer components and usually quieter
