Oct 19th, 2024, 2:24pm
Mixer Analysis (Read 1040 times)
aaron_do
Mixer Analysis
Jun 11th, 2008, 8:50pm
I'm trying to understand the analysis of a passive mixer. In order to find the conversion gain, i think i need to:
1) Write the periodic time-varying equation for the switch resistance in a fourier series expansion
2) Write differential equations to describe the circuit input output relationship.
3) Take the fourier transform of the differential equation while substituting the fourier transform of the fourier series expansion of the switch resistance.
4) Take the harmonics i want and call it the conversion gain...
Is that right?
Basically i end up with something like
Vout(jw) = G*Vin(jw + jwLO)
where i have removed all unwanted frequency components of both Vout and Vin, and jw is the IF and iw+wLO is the RF input. G is the conversion gain...
thanks,
Aaron
« Last Edit: Jun 12th, 2008, 8:41am by aaron_do »
