analocation
Hi, I would like to convert a Spice net list into a schematic via SKill code. However, I have a problem in connecting transitor terminals, because the command "schCreateWire" requires the explicit coordinates of the terminal to be wired. Is there any command, that returns the coordinates for the bulk, gate , drain and source terminals of a certain transistor or a different command that provides an easy way to connect the terminals?
