rfmems
Hi Ryan,
What I mean by "avged noise count only the noise around the fundamental tone", is the noise after conversion. And 'number of harmonic' counters only for the mixing (up conversion) effect. Bbut when you plot your phase noise around the foundamental, it is actually only the noise around the fundamental tone after conversion. Whereas the timedomain noise simulation really counts all the noises around the harmonics which affect thr zero crossing. I have done a number simulation with quite basic circuits like inverters and so on, always get a higher noise with strobed simulation. But give it a second thinking, I think wether the stobed noise should be higher or lower really depends on the slew rate, it you have a infinite slew rate, then strobed noise will be actually 0 after converted to phase noise. As you said, avergae noise and strobed noise are differnent stories, so we should not compare them anyway. One is physical, one is not.
