Oct 31st, 2024, 7:40am
DC/DC Used In BC3 (Read 3774 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
DC/DC Used In BC3
Jun 14th, 2008, 12:47am
Hi folks,
Long time no see, I have been ill for several months, this is the first time I return DGC, I miss you guys so much! I got a DC/DC circuit used in BC3, but I don't know what's its function and what's it used for, can you give me some suggestions?
Best regards,
Terry
Re: DC/DC Used In BC3
Reply #1 - Jun 16th, 2008, 1:23pm
More information!
Is that an op-amp or a comparator?
Whats the input signal?
Whereis the negative input to that op-amp connected?
And, anything welse that you know.
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #2 - Jun 17th, 2008, 11:49pm
loose-electron wrote on Jun 16th, 2008, 1:23pm:
More information!
The input signal is from the BC3 core, and the negative input to the op-amp is connected to a bias voltage generated by the bandgap in the DC/DC block, the figure shown below is the comparator used, VB is also a bias from the bandgap in the DC/DC.
Reply #3 - Jun 23rd, 2008, 12:52pm
Detective hat on:
What you have is a pass thru system (a source follower and not much else) up to a certain amplitude.
Above a certain amplitude the comparator kicks in and limits the output.
Not sure what it is getting used for, but at first glance thats what it does.
Jerry
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #4 - Jun 23rd, 2008, 8:03pm
loose-electron wrote on Jun 23rd, 2008, 12:52pm:
Detective hat on:
Jerry
Hi loose-electron,
You mean amplitude, not frequency? But there is a C1, in steady state, the right plane of C1 will be 0 voltage, can you give me some more details about how it works towards amplitude.
Best regards,
Terry
Reply #5 - Jun 24th, 2008, 11:29am
Up to a certain amplitude, yes. The system is AC coupled, so the frequency dependence is a matter of input signal and spectral content vs where the roll off point is of the ac coupling.
Spectral depedence is going to be tied to the relative locations of those two. My premise is that AC coupling exists only to remove the DC content. Best I can do depending on the limited data available.
