qiushidaren wrote on Jul 20th, 2008, 7:58pm:Yes, I got the right model and right type, and I changed both the lmin/lmax and the wmin/wmax values, but it still said that, I don't know why, maybe there are some other values that are relative with the wmin/wmax and lmin/lmax parameter?
How do you know you got the right model and type? Why did you change wmin/wmax if it was length that was out of range? I would have just changed lmax to 1 meter. (If you set lmax=40u, it could be that "DL" makes the device have a slightly longer channel so it doesn't fit the bin.)
Can you cut out a single instance of the model from the library file and run it? How complicated is the library -- I've seen some with "sections" and "includes" that make it quite difficult to find what's actually being simulated (eg, maybe you changed lmax in the fast corner rather than nominal).
