Jul 17th, 2024, 12:21am
About the error " internal timestep is too small" (Read 5727 times)
icsoul
Jun 18th, 2008, 3:05am
When measuring the frequency of a clock, I got the error information, " the internal timestep is too small".
My code  is list in the following:
         @(cross(V(clk)-vth, +1))begin
               current_time = $realtime;
                       if (last_time > 0.0)
               period = current_time - last_time;
               freq = 1/period;
                       last_time = current_time;
         V(pout) <+ period;
         V(fout) <+ freq;
I think the problem comes from the statement, V(fout) <+ freq; .
Why it has no problem when using "V(pout) <+ period;",  while it has the problem when using the statement "V(fout) <+ freq;"?
How to solve this?
Thanks !
Stefan
Re: About the error " internal timestep is too sma
Reply #1 - Jun 18th, 2008, 3:18am
The simulator tries to tighten the time steps until the convergence criteria abs[V(fout,t0)-V(fout,t0+delta T)] < epsilon is met.
Try normalizing your frequency output by a factor, that should help.
View Profile 16731287   IP Logged
icsoul
Reply #2 - Jun 19th, 2008, 2:18am
Stefan wrote on Jun 18th, 2008, 3:18am:
Thanks, Stefan.
Then how to normalize the frequency output?
I'm puzzled by this problem.  the "V(pout) <+ period" works ok, while the "V(fout) <+ freq" does not work. I think they have the same quantity level. Why one works, but the other does not work?
Reply #3 - Jun 19th, 2008, 6:34pm
ICsoul,
  For example for a PLL for Wireless LAN, normalize the frequency to GHz.
V(fout) <+ freq/1e9;
In general, having large ranges of numbers can cause simulators issues. Don't know
your application, but if the VCO has high kco then small variations, > 1mV, on the
control line cause big changes in the output frequency. On the other hand frequency
node may be a > 1GV.
icsoul
Reply #4 - Jun 19th, 2008, 10:43pm
sheldon wrote on Jun 19th, 2008, 6:34pm:
ICsoul,
Sheldon,
My application is to construct a pll model.
I had used the method you mentioned ever before. But the problem is still there.
The period has a quantity level 1E-9,  it works ok. While the frequency has a quantity level 1E9, it does not work.
So there may be other reasons that cause this prolbem.
Reply #5 - Jun 19th, 2008, 10:54pm
How big is V(fout)?
What is your supply voltage?
icsoul
Reply #6 - Jun 22nd, 2008, 4:58am
Ken Kundert wrote on Jun 19th, 2008, 10:54pm:
How big is V(fout)?
My supply voltage is 1.2V.
V(fout) is 0.279044V.
V(pout) is 3.5837V ( after x1E9 in the module), but this result is ritht.
Re: About the error " internal timestep is too small"
Reply #7 - Jun 22nd, 2008, 11:27am
The period is 3.5ns and the frequency is 0.279Hz?
Are you now normalizing the value of fout, or is the output voltage really 279MV?
What is fout driving? Do you need to connect the output frequency to the rest of your circuit, or do just want it available for plotting?
icsoul
Reply #8 - Jun 23rd, 2008, 5:04am
MY code:
`include "disciplines.vams"
`include "constants.vams"
module period_freq_meas (clk, pout, fout);
           input clk;
           output pout, fout;
           electrical clk, pout, fout;
           parameter real vhi = 1.2 ;
           parameter real vlo = 0 ;
           parameter real vth = (vhi+vlo)/2 ;
   real last_time, current_time, period, px, freq;
   analog begin
         @(initial_step)begin
                       last_time = 0.0;
                       period = 0.0;
               px = period*1E9;
               freq = 1/px;
         V(pout) <+ period*1E9;
         V(fout) <+ freq;
                 @(final_step) begin
                       $strobe("freq = %g", 1/period) ;
                       $strobe("period = %g", period);
                       $strobe("fx = %g", 1/px);
                       $strobe("px = %g", px);
And the stimulus:
X0 clk pout fout period_freq_meas
Vin      clk      0      SFFM(0.6 0.6 2E8 5 2e7)
Please help to check it.
Thanks!~
