Jess Chen
In addition to the above limitations, there is one more important one: "all the time". i.e. you can only pass one real number, one way, all the time. The last constraint means you can't turn off a wreal; there is no high impedance state. Thus, even though you physically only turn one of two parallel circuits on at a time, you cannot tie their wreal outputs together.
