Jul 17th, 2024, 12:36am
Syntax Error when using spectre to simulation verilog-A file. (Read 1886 times)
Julian18
Jul 20th, 2008, 3:15am
Hi, there
   I am very new to verilog-A field, so bear this simple question. I am runing Ken's sample and hold example and got the error like below:
Quote:
Error found by spectre during AHDL read-in.
   "sh.va", line 5: "'<<--? include "discipline.h""
   "sh.va", line 5: Error: syntax error
   "sh.va", line 11: "electrical       Pin,<<--?      Nin,    Pout,   Nout;"
   "sh.va", line 11: Error: syntax error
I am just using the spectre from command line(instead of simulating in ADE) and the command is
Quote:
spectre s_and_hold.scs
I wonder if I have to add some options in order for spectre to realize that the file contains verilog-A statements.
TIA.
« Last Edit: Jul 20th, 2008, 5:43am by Julian18 »
Re: Syntax Error when using spectre to simulation verilog-A file.
Reply #1 - Jul 21st, 2008, 8:57am
Did you
ahdl_include "sh.va"
in your .scs file?  (Or were you using a regular include like for model files?)
