Jul 18th, 2024, 4:15am
Is it possible to import *.csv file into Cadence? (Read 5963 times)
rf_man
Jun 20th, 2008, 6:35am
just wanna to import *.csv file into cadence for convenience of comparison sim.&meas. data.
Stefan
Re: Is it possible to import *.csv file into Caden
Reply #1 - Jun 20th, 2008, 6:38am
You could try to user your .csv files as input for a PWL source use that output to be plotted in wavescan.
Don't know if that is what your thinking about anyway ...
View Profile 16731287   IP Logged
rf_man
Reply #2 - Jun 20th, 2008, 8:34am
as input to pwl source? how do you do that? see below.
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Is it possible to import *.csv file into Cadence?
Reply #3 - Jun 21st, 2008, 2:30am
I've used vpwlf component(it has a field for the path of the file) for this task(for example to enter a modulated signal generated with Matlab). Another option is to save the sim in csv format and load the data from meas and sim with another program for signal processing.
Hope it helps,
