acezhy
For CML buffer working at rather low frequency, and considering two cascaded buffer, the jitter of the preceding block is independent of the succeeding block. But for the same cascaded CML buffer operating at a high frequency (the signal becomes a continuous one and no high/low level achievable), does the same rule valid?
Recently, I simulated the cascaded CML buffer with pnoise jitter method operating at high frequency, and by changing the parameter of the last stage, and checking the noise contribution table, I found more noise power from the preceding component becomes larger. It seems that the jitter of the preceding stage is amplified? Anyone could help explaining this case?
Thank you all!
