Oct 31st, 2024, 5:11am
a question about overdrive voltage&sub-threshold (Read 3921 times)
cetacean
Jun 27th, 2008, 4:28am
In the CMOS Op-Amp Design, it often mention that ensure MOS transistors operate far away from the subthreshold region,describe to operate the transistors wiht a minimum gate overdrive voltage.
Vgs - Vt = sqrt(I*L/uCox*2W) >= Voverdrive,min
but when the current is very low,base this equ ,the W/L would be too large.
so i want to know when it's low current ,how to fix the W/L?
aaron_do
Re: a question about overdrive voltage&sub-threshold
Reply #1 - Jun 27th, 2008, 5:36am
why do you say that when the current is small, W/L is large?
If you want the same Vgs-Vt and you reduce I, then you must reduce W/L...
cheers,
Aaron
cetacean
Reply #2 - Jun 29th, 2008, 6:14pm
i'm so sorry to make a stupid mistake. Actually i wanna to say the W/L would be very very small.i.e. i=5uA,and the Vgs-Vth=0.2v in 0.6um CMOS process
aaron_do
Reply #3 - Jun 30th, 2008, 1:20am
Good question. Apart from increasing L, operating in subthreshold, or using some kind of source degeneration...i'm not sure.
cheers,
Aaron
cetacean
Reply #4 - Jun 30th, 2008, 2:50am
Thanks for your answer!
but the MOS transistors turn into sub-threshold region,i/(W/L)shold be less than about 100nA.then the w/l would large enough,in fact too large i think.
how to fix the sizing when the current is small have been haunting me for a long time. Sad
Berti
Reply #5 - Jun 30th, 2008, 4:25am
I think that sub-threshold is usually avoided in high-speed design because large transistors
are necessary. But an OTA with 100nA bias current is probably not high-speed - and you can operate transistors in sub-threshold region.
cetacean
Reply #6 - Jun 30th, 2008, 4:41am
I should correct that:no the bias current 100nA,but the current of per W/L is 100nA
