Jul 24th, 2024, 1:08pm
eye diagram of VCO (Read 3973 times)
analog_cha
India
eye diagram of VCO
Jul 01st, 2008, 4:28am
How many cycles of the VCO output  one can take to plot the eye diagram to find the peak to peak jitter??
Because as the number of cycles increase the pk to pk jitter also increases.
Thanks.
Frank Wiedmann
Munich, Germany
Re: eye diagram of VCO
Reply #1 - Jul 1st, 2008, 6:38am
The jitter of a free-running VCO with white noise sources is proportional to the square root of the time between the two observed transitions. See section 10 of http://www.designers-guide.org/Analysis/PLLnoise+jitter.pdf for details. So, it does not make much sense to talk about the peak-to-peak jitter of a free-running VCO because it is infinite if you observe it for an infinite time.
Reply #2 - Jul 3rd, 2008, 12:19pm
for a closed loop system its a different story.
You are seeing the additive data points in a Gaussian distribution when you run over multiple cycles. So, how well do you want to define the distribution?
HdrChopper
Reply #3 - Jul 3rd, 2008, 7:17pm
Based on what loose-electron suggested, I would wait for a "representative" number of cycles for guaranteeing 6 sigma distribution. I´m assuming the pk2pk jitter to be six sigma provided we see the cumulative Gaussian distribution.
Such number for me would be about 1000 cycles, since that should be the min # of cycles in order to see 1 event outside the six sigma population.
Rgds
Tosei
Keep it simple
analog_cha
India
Reply #4 - Jul 4th, 2008, 1:34am
Thank you very much to all.
