Turin
Greece
If you have an implemented circuit(for instance a MOS intergrator) in 1.2μm technology and you want to re-desing it in a different technology,for example 0.35μm, what steps you need to take when it comes to the transistor parameters?Do you need to define something more than different aspsect ratios in order to have the same circuit in the different technology?Thanks!
