May 2nd, 2024, 10:39pm
Warning signal with smash (Read 4000 times)
Lucas67
Jul 04th, 2008, 3:14am
I begin in VHDL-AMS and I try to use the software SMASH.
I wrote a little program. When I compil it, I have one warning :
"WARNING: signal 'COUPLE' is not driven by any gate or process output."
What is the matter ?
This is my program :
>>> VHDL
library IEEE;
use IEEE.math_real.all;
use IEEE.mechanical_systems.all;
use IEEE.std_logic_1164.all;
ENTITY car IS
     GENERIC (M:mass:=1500.0);
     PORT (SIGNAL couple : IN REAL);
END ENTITY;
ARCHITECTURE behav OF car IS
     CONSTANT roue: real:=0.2;
     QUANTITY acc : acceleration ;
     QUANTITY vitesse : velocity ;
BEGIN
     acc == couple/(M*roue);
     vitesse'dot == acc;
END ARCHITECTURE behav;
ENTITY TB IS
END;
use WORK.ALL;
ARCHITECTURE One OF TB IS
SIGNAL couple : real ;
BEGIN
     voituretest : ENTITY car (behav)
     PORT MAP (couple);
     couple <= 50.0;
END ARCHITECTURE One;
alinalin19832007
roman
Re: Warning signal with smash
Reply #1 - Jul 13th, 2008, 12:46pm
hi
I think u have to put the signal couple in a process in TB
Lucas67
Reply #2 - Sep 16th, 2008, 12:30am
You're right. the signal couple is in a process in TB.
I changed that and the warning disappear.
Thank you very much for your help.
