boa
I need to make a Verilog-A model for temperature protection block and it should have temperature hysteresis: i.e. output should switch from zero to one at one treshhold temperature when temperature is rising and at different one when the temperature is following. Normally for comparator with hysteresis I would use 2 cross statements with +1 and -1 direction, but it seems that cross works only for transient and I need smth that will work with DC sweep.
Is there any way to implement it?
