Jul 24th, 2024, 3:21am
dynamic range of CT delta-sigma modulator with jitter (RZ/NRZ DACs) (Read 7033 times)
vivkr
Jul 15th, 2008, 2:36am
We know that NRZ DACs are less jitter sensitive than RZ DACs for CT delta-sigma ADCs.
However, the dynamic range, or the lowest input signal for which you get good SNR (say 0 dB SNR)
ought to be the same for both cases RZ/NRZ.
At large signal levels, the modulator has very low activity factor and so there are very few transitions in a NRZ-type modulator which improves jitter-limited SNR.
But as one goes on reducing the signal level, the activity increases. For a 1-bit quantizer, we will have more or less a 1 0 1 0 1 0 kind of pattern out of the quantizer (modified a bit by the modulator). But basically, there will be quite a bit more activity which would mean that the jitter sensitivity becomes almost the same as for a RZ type DAC.
Since one of the main reasons for a  high dynamic range (DR) requirement is the ability to resolve small signals, this seems to be equally good (or poor) no matter whether one uses RZ or NRZ DACs in CT delta-sigma modulators.
Or am I missing something ?
Vivek
Stefan
Re: dynamic range of CT delta-sigma modulator with jitter (RZ/NRZ DACs)
Reply #1 - Jul 15th, 2008, 2:47am
You are right, if you're just considering a single input.
The problem occurs especially when dealing with another signal, like a blocker or interferer, which is sorted out in the digital domain using e.g. a CDMA system. You'll then have to detect small signal changes, under presence of a large signal interferer.
View Profile 16731287   IP Logged
vivkr
Reply #2 - Jul 16th, 2008, 7:23am
Hi Stefan,
All that is fine, when speaking about a real world application. However, what I am trying to say is that a manufacturer/designer does not really get any advantage in terms of the dynamic range (DR) measured in the lab and hence its value in the datasheet when using NRZ, atleast in terms of jitter. There are other advantages such as slew etc. in design.
But if I were to make 2 CT DSMs (one with RZ and one with NRZ) and apply nice, clean, single tone signals to them in the lab, then I should see the jitter-limited DR to be the same, because as I begin to reduce the signal strength, there are more and more 1-0-1-0 kind of transitions, and even the NRZ DAC output looks more and more like an RZ DAC output. So, same minimum noise floor results in either case.
This is all just with a single-bit quantizer mind you. A multibit quantizer may show the difference between RZ and NRZ, but the difference will depend strongly on the design of the modulator. If the modulator is very stable, the quantizer outputs may still swing back and forth between just 2-3 levels and one may still see no difference in terms of jitter-limited sensitivity. What do you say to that?
Vivek
vrl
Bangalore, India
Reply #3 - Jul 17th, 2008, 7:01pm
A CT sigma-delta modulator with RZ feedback, but same NTF as one with NRZ feedback, would have feedback pulses that are higher in amplitude in order to provide the same feedback information.
As a result, even in the case when the NRZ pattern is 1-0-1-0, the RZ case will suffer more from jitter due to the higher amplitude of the feedback pulses.
Pls correct me if I'm wrong.
vivkr
Reply #4 - Jul 17th, 2008, 11:26pm
vrl wrote on Jul 17th, 2008, 7:01pm:
Why would that be so? If we take a 1-bit DAC. Say the reference voltage is +1 V for quantizer output = +1 and -1 V for quantizer output = 0.
Now NRZ 1,0,1,0 gives +1,-1,+1,-1
RZ has  +1, 0, -1, 0, +1, 0, -1, 0.
The RZ case has the same total transition step but the difference is that it first switches to 0 before going down to -1.
Vivek
vrl
Bangalore, India
Reply #5 - Jul 18th, 2008, 9:14am
Hi Vivek,
   Assuming that we need to provide the same amount of feedback, the fact that the RZ waveform is 0 for part of the cycle would mean that the DAC levels would need to be > ±1 during the rest of the cycle.
Ref: Shouli Yan, and E. Sánchez-Sinencio,"A Continuous-Time ∑∆Modulator With 88-dB Dynamic Range and 1.1-MHz Signal Bandwidth", IEEE Journal of Solid-State Circuits, Volume: 39 Issue: 1 , January 2004, Page(s): 75 -86
regards,
Vijay
vivkr
Reply #6 - Jul 20th, 2008, 11:39pm
Hi Vijay,
Thanks for pointing out the fine detail. But I think this is still a fine detail. If the pulse in a RZ waveform is 99% as wide as in a NRZ waveform, then one would need to make it 1/0.99 times larger in amplitude. So, a small correction factor. I expect that this factor is not > 1/0.9.
I think this correction factor may make a difference of < 0.5 dB. But the situation remains quite comparable for low signal levels between RZ and NRZ, as far as jitter is concerned.
Any other things that might make it worse. I am just trying to see whether there really is such a great problem using RZ with a 1-bit quantizers as long as I am interested in SNR at low signal amplitudes.
But perhaps I will anyway take the suggestions posted elsewhere in this discussion and use a multibit DAC, with NRZ of course, to save on slew and jitter sensitivity.
Vivek
Berti
Reply #7 - Jul 21st, 2008, 12:34am
Hi Vivek,
I fully agree with Vijay.  And when the RZ pulse-width approaches the NRZ (e.g. 99% as you suggest) the difference will vanish. However, this is difficult to implement (requires very accurate timing), and in real implementation the RZ pulse-width will therefore always be considerably shorter than NRZ pulses.
vivkr
Reply #8 - Jul 21st, 2008, 5:59am
Hi All,
Thanks for the responses. I now have sufficient insight. So looks like I have to go with NRZ, and multibit, and make sure that ISI is not significant (some suppression due to differential scheme).
Vivek
