Jul 2nd, 2024, 5:44pm
how to select the gate length (Read 2669 times)
wwm101
china
Jul 15th, 2008, 4:34am
in analog design ,gate length has been selected  many times as min gate length。
how about in rfic?in many paper,i find they select  gate length as long as min gate length。but  actually?
thank you in advance
View Profile wwm101 weiming022002@yahoo.com   IP Logged
Stefan
Re: how to select the gate length
Reply #1 - Jul 15th, 2008, 4:39am
I don't understand your question. Dimensioning a transistor is one of the most complex operations in design.
Larger transistors suffer less from matching,
smaller transistors are cheaper in area and have less parasitic capacitance,
shorter transistors have a lower on-resistance, but also a lower off-resistance, wider transistors can lead more current but provide a larger gate capacity, which limits their switching time ... and so on ...
The smaller you CAN make your transistors, the cheaper your chip will be in the cost of area. However, making the transistors smaller might increase noise, so that you will have to provide more bias current, which will be expensive in terms of power consumption ...
As you can see, there's no "general" answer to your question ...
(and we didn't even talk about matching, temperature, ...)
View Profile 16731287   IP Logged
analogue_guy
Reply #2 - Aug 9th, 2008, 1:07pm
Choosing the proper length is always a big trade off, as was mentioned before the matching, area, speed, parasitics, temperature dependency... depends on that and one other thing which is more and more important: leakage currents.
