KDB
The provisions of SLIMbus allow LPCM data to be transported at a number of different bit widths and sample rates. Therefore, it is possible to have some "standard" 44.1KHz, 16 bit digital audio being transported, which is what is often referred to as CD Quality. But higher and lower sample rates can also be transported, as well as bit widths up to 32 bits.
Therefore, and DAC or codec filters would have to be tailored for what rates and bit widths you want to support, and the ability to adjust depending upon the incoming sample rate/bit width format.
SLIMbus itself does not impose any particular filter characteristics.
KDB
