Aug 16th, 2024, 6:22pm
error when simulating Verilog-A model in ADE (Read 4293 times)
Pavel
Lausanne/Switzerland
Jul 22nd, 2008, 8:14am
I just tested verilog-A model of nonlinear resistor that I have found in Cadence manual. Here i is.
module RX_RES_MDL_book (a, b);
inout a, b;
electrical a, b;
real x[0:17], y[0:17], f_xy[0:17];
analog begin
@(initial_step) begin
	x[0]= -10; y[0]=-10; f_xy[0]=0; // 0th sample point
	x[1]= -10; y[1]=-8; f_xy[1]=-0.4; // 1st sample point
	x[2]= -10; y[2]=-6; f_xy[2]=-0.8; // 2nd sample point
	x[3]= -9; y[3]=-10; f_xy[3]=0.2;
	x[4]= -9; y[4]=-8; f_xy[4]=-0.2;
	x[5]= -9; y[5]=-6; f_xy[5]=-0.6;
	x[6]= -9; y[6]=-4; f_xy[6]=-1;
	x[7]= -8; y[7]=-10; f_xy[7]=0.4;
	x[8]= -8; y[8]=-9; f_xy[8]=0.2;
	x[9]= -8; y[9]=-7; f_xy[9]=-0.2;
	x[10]= -8; y[10]=-5; f_xy[10]=-0.6;
	x[11]= -8; y[11]=-3; f_xy[11]=-1;
	x[12]= -7; y[12]=-10; f_xy[12]=0.6;
	x[13]= -7; y[13]=-9; f_xy[13]=0.4;
	x[14]= -7; y[14]=-8; f_xy[14]=0.2;
	x[15]= -7; y[15]=-7; f_xy[15]=0;
	x[16]= -7; y[16]=-6; f_xy[16]=-0.2;
	x[17]= -7; y[17]=-5; f_xy[17]=-0.4;
	I(a, b) <+ $table_model (V(a), V(b), x, y, f_xy, "");
When I simulated following testbench (pls, see the picture), following error message appears in log window.
Fatal error found by spectre at dc = 0 A during DC analysis `dc'.
    "....../LIB11/RX_RES_MDL_book/veriloga/veriloga.va"
        31: $table_model failed: zero dimension not allowed --
Analysis `dc' terminated prematurely due to error.
What signifies this message?
Thanks.
Regards.
Pavel.
Re: error when simulating Verilog-A model in ADE
Reply #1 - Jul 22nd, 2008, 12:49pm
Works OK for me ...  you might want to put "L,L" instead of "", though I think that's the default.
Pavel
Reply #2 - Jul 22nd, 2008, 11:49pm
Thanks Geoffrey. I tried your proposition. Here is the result:
        31: $table_model failed: cannot open file `L,L'
Reply #3 - Jul 28th, 2008, 8:10am
Hmm ... it may be that your simulator is too old a version.  The $table_model in LRM 2.2 was donated by Cadence based on their implementation at the time, but it may be that it only supported file-based data, and the array data capability was added by the committee.
