Jul 21st, 2024, 12:25am
how to re-run tran with last simulation results? (Read 3505 times)
jlee
Jul 29th, 2008, 10:34pm
Dear guys,
Does anyboby knows how to re-run tran with last simulation results that include all nodes operating point?
I remember some guy also asked the same question in the forum, but I can't find out the web.
Jason Cheesy
bernd
Munich/Germany
Re: how to re-run tran with last simulation results?
Reply #1 - Jul 30th, 2008, 2:15am
You have to create 'saved state' or 'checkpoint' file and restart your simulation
with the 'recover' option.
Virtuoso Spectre Circuit Simulator User Guide
Running a Simulation
Recovering from Transient Analysis Terminations
In the transient options
  • 'write' writes the 'saved state' file from the initial point.
  •  'writefinal' writes the 'saved state' file from the final point.
    usually this files are called 'spectre.ic' and 'spectre.fc'
  •  'recover'  specifies the 'checkpoint' or 'saved state' file to read.
> spectre -help | grep -A1 recover
+recover[=filename]
                 Restarts the simulation from a checkpoint or savestate file,.
You have to try it. I have not done this for a long time.
Have also a look at
http://www.designers-guide.org/Forum/YaBB.pl?num=1186585475/2#2
* bernd
Just another lonesome cad guy
dongzz201
China
Reply #2 - Jul 31st, 2008, 8:56pm
if HSPICE is used, then how to re-run the trasnient ?
Reply #3 - Aug 5th, 2008, 10:38pm
Hi Bernd,
After an interruption because of tranient non-convergence, I re-run the simulation as what you instructed. However, the waveform before the interruption is overwritten. In fact I wanna combine the waveform  before and after the interruption into one so that a DFT/fourier analysis is done. Otherwise a lot of data is lost and the remaining data is not enough to run DFT.
Any comments are appreciated.
Yawei
« Last Edit: Aug 6th, 2008, 12:33am by ywguo »
