Jul 17th, 2024, 11:25am
Double input dc-dc converter output voltage for one input and input current for (Read 7397 times)
jay kumar
Jul 30th, 2008, 10:45pm
Hi, I am new to this forum.Actually i have doubt regarding to the control loop design in DC-DC converter.
I want to design voltage loop and current loop for multi-input dc-dc converter.For that i want to use method like sequential loop closing method or any other method. How to design control loop for this case .... will it be dependent on voltage loop? I want to design current loop to keep input power always same and voltage loop to keep output voltage always same and it is double input dc-dc converter. How to design such control loops? i know design of single voltage loop. but how voltage and input current loop can be designed for double input dc-dc converter?
Eugene
Re: Double input dc-dc converter output voltage for one input and input current for
Reply #1 - Jul 31st, 2008, 8:11am
Jay,
Before you dive into the control aspects of your converter, make sure you have thought through the physics of your proposal. You are asking for a constant power at the input and constant voltage at the output. I assume you want to regulate the output voltage because the load will vary. As the load varies with output voltage held constant, the output power will vary. The only way you can vary output power without varying input power is to vary the efficiency. Is that really what you want to do?
If you want to control input power only at a very high frequency while you control output voltage at a very low frequency, you might be able to come up with an appropriate control scheme but why not just use an input filter if that's what you have in mind?
jay kumar
Reply #2 - Jul 31st, 2008, 10:48am
This converter is combination of two converters with two switches(MOSFET) so i want to converter input power of one using duty ratio of corresponding converter and output voltage of converter using another converter switch.So it is kind of MIMO system and it is a converter made up of two converters e.g. one buck and other buck-boost converter integrated with each other sharing one common output inductor.So it is kind of integrated converter made up of two converters.So two switches which u can control .So i just want to have control strategy for it....I think it is MIMO system
Eugene
Reply #3 - Jul 31st, 2008, 10:42pm
Look at it from an input power in versus output power out standpoint. It really doesn't matter how many converters, switches or control loops you include between the input and output, you still have the problem of varying the efficiency of the overall system if you want to control both input power and output voltage. Do you care about efficiency?
jay kumar
Reply #4 - Aug 1st, 2008, 4:45am
I want to design for voltage controller and current controller for such system. It is MIMO system and i am not getting how to design controller for MIMO system
Eugene
Reply #5 - Aug 2nd, 2008, 10:31am
Jay,
You're not answering my question about efficiency, but if I were to deduce one from your entries, I'd say you don't care about the efficiency of your proposed system. OK.
Do you want to control input power independent of output voltage? If not, then why do you need these two control loops? If you do want independent controls, then given that the output power can only be less than or equal to the input power, what do you plan to do with the excess power?  I must be missing something.
I'll back out of this discussion at this point and give someone else a chance to help. Good luck.
