Eugene
Jay,
You're not answering my question about efficiency, but if I were to deduce one from your entries, I'd say you don't care about the efficiency of your proposed system. OK.
Do you want to control input power independent of output voltage? If not, then why do you need these two control loops? If you do want independent controls, then given that the output power can only be less than or equal to the input power, what do you plan to do with the excess power? I must be missing something.
I'll back out of this discussion at this point and give someone else a chance to help. Good luck.
