Jul 21st, 2024, 4:21am
spice netlist (import) simulated from Cadence GUI? (Read 4917 times)
wave
Aug 06th, 2008, 3:51pm
Hello -
I'm working on a project we're trying to migrate all netlists into a cadence schematic, and use the favorite old GUI such as the Analog Design Environment (ADE).
In the mean time, I have IP blocks with spice netlists only.
Question:  inside a Cadence schematic, can I instantiate a symbol that references such a netlist, and run spectre (spice format)?
If so, exactly, how do I do this?
thanks!
the Wave Cool
bernd
Munich/Germany
Re: spice netlist (import) simulated from Cadence GUI?
Reply #1 - Aug 7th, 2008, 1:45am
There was a similar post a few days ago maybe this helps.
http://www.designers-guide.org/Forum/YaBB.pl?num=1191334088
* bernd
Just another lonesome cad guy
bernd
Munich/Germany
Reply #2 - Aug 7th, 2008, 1:45am
* bernd
wave
Reply #3 - Aug 7th, 2008, 3:59pm
Hi Bernd - thanks.
I got the scasubckt symbol to work.  Seems fine.
Now, the office discussion is, why is that necessary?  Can we use a normal symbol and create a netlist view, that contains the same file.sp
cheers
Wave
Cool
bernd
Munich/Germany
Reply #4 - Aug 8th, 2008, 2:15am
No it is not necessay, but it's probably the easiest way to do it.
You can use your own symbol as well, but you need in addition.
  • A stop view for the simulator e.g. spectre,
    symbol view could be copied over to 'spectre' for that.
  • The cell CDF has to be created or modified.
  • A model file where you have you IP spice description an which is
    included in the simulators model path.
* bernd
