Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 21
st
, 2024, 2:25am
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› stability check for Charge pump
Previous topic
Next topic
stability check for Charge pump (Read 2363 times)
Won
Jul 24
th
, 2008, 10:11am
Hi, Guys
I try to verify stability of regulated charge pump.
I don't know how to check stability of it.
Do you know how to simulate stability of regulated charge pump circuit?
Best regards,
Won
IP Logged
Frank Wiedmann
Munich, Germany
Re: stability check for Charge pump
Reply #1 -
Jul 24
th
, 2008, 11:49pm
Use the pstb analysis of SpectreRF. Search this forum for "pstb" for further information.
IP Logged
wave
Reply #2 -
Aug 6
th
, 2008, 3:55pm
assuming this is a switch cap CP regulator,
, another basic way is to run a transient.
Low accuracy probably OK for speed.
Watch the settling response, which would imply Phase Margin. (ie, under/over damped control theory)
the Wave
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
