Jul 19th, 2024, 4:24am
spectre error in transient sim. (Read 7335 times)
lrc
Grrr....
U.S.A
Aug 07th, 2008, 9:41am
I am running a transient simulation using spectreVerilog, the simulation always stopped by the error below.  Can anyone please tell me what might be the cause and how to avoid it?
Thanks very much.
Zhenning
Error found by spectre at time = 61.9654 us during transient analysis `tran'.
   ERROR: Error in transient analysis IPC.
   ERROR (SPECTRE-16328): Error in transient simulation for mixed-mode.
Analysis `tran' was terminated prematurely due to an error.
finalTimeOP: writing operating point information to rawfile.
Error found by spectre during DC analysis, during info `finalTimeOP'.
   ERROR: Error in cleaning up IPC code in an attempt to quit.
   ERROR (SPECTRE-16329): Error in DC simulation for mixed-mode.
Analysis `finalTimeOP' was terminated prematurely due to an error.
DC Analysis `dcOp'
Error found by spectre during DC analysis `dcOp'.
   ERROR (SPECTRE-16041): Analysis was skipped due to inability to compute operating point.
Analysis `dcOp' was terminated prematurely due to an error.
dcOpInfo: writing operating point information to rawfile.
Error found by spectre during DC analysis, during info `dcOpInfo'.
bharat
Re: spectre error in transient sim.
Reply #1 - Jan 25th, 2009, 8:20am
Did you get the answer to that?
Reply #2 - Jan 27th, 2009, 11:18am
sounds like something you should report to Cadence R&D.
Reply #3 - Jan 27th, 2009, 12:53pm
This can happen (from a little research I did) when the verilog executable dies during the mixed-signal simulation. Spectre then reports it as seen above, because it can no longer talk to it.
I've found a few cases:
  • verilog ran out of memory
  • verilog wrote too big an output file
  • a system admin killed the process because it had been running a long time
  • licenses were released by verilog after a period of inactivity, and then couldn't be reclaimed later, and so verilog stopped.
  • use of some $wdf tasks to interface to the Synopsys Spice Explorer Tool
  • Path to some old version of verilog in the ADE->Digital Option setup.
  • Having a very old version of verilog in your path (use a recent IUS version)
There seemed to be lots of possible reasons - this was just a sample. I'd look in the verilog log file and see if that gives any clues...
