This sounds to me like an issue with your OS and Cadence IC.
Some suggestion.
1. Contact you Cadence customer support because this is really hard to
debug through a forum like this.
2. Cadence offers a tool which checks your OS and patches for the
correct prerequisites for your Cadence installation try it.
http://sourcelink.cadence.com/docs/files/download/sys_conf_check/ 3. Try to set the UNIX environment variable
csh:
setenv DD_DONT_DO_OS_LOCKS seThe are some SKILL function which are loaded twice through your setup
function <BlaBal> redefinedalso Cadence environment variables s form a different tool version which now are not found any more
*WARNING* envSetVal: Can't set the value of variable 'BlaBla',
in tool[.partition] 'schematic' - it has not been registered.
explore where this things are coming from and try to ge rid of theses.
* bernd
