Jul 19th, 2024, 6:25am
Problem in setting up Analog Design Environment - XL/GXL in IC613 (Read 1887 times)
VP
Sunnyvale
Jan 26th, 2009, 12:11am
I am trying to setup IC613 in my local UNIX account at my university. Attached are the common environment setup files used by me. Following are the steps that I use for invoking IC613:
1. Source the design_environment_613.csh from my 'home' folder
2. The 'cdsinit' file is located in the directory from which I start the 'CIW'.
3. The 'cdsenv' and 'cdsplotinit' files are located in my home directory.
The problem is that when I try to start ADE-XL or ADE-GXL from the schematic editor, it throws up some strange error "*Error* eval: undefined function - _SessionIlCmdWrapper". The complete warning and error message is present in the CDS.log file.
I am not sure whether there is some setup issue or not. Has anyone faced this kind of error while working with IC613?
Any kind of inputs is highly appreciated.
---VP
Re: Problem in setting up Analog Design Environment - XL/GXL in IC613
Reply #1 - Jan 27th, 2009, 12:56pm
