Jul 23rd, 2024, 11:19pm
using offset to move idle tones in audio delta-sigma modulators (Read 2576 times)
vivkr
Aug 08th, 2008, 3:01am
Hi All,
I would like to know if there is a generic method for predicting the tone location based on the offset level at input for a delta-sigma modulator.
I remember having read somewhere a formula like: f_tone = (offset/fullscale_voltage)*f_clk
However, I don't remember where and so I am not sure what assumptions led up to this equation, and if it is really valid, and for an arbitrary delta-sigma modulator.
Any comments would be appreciated.
Vivek
HdrChopper
Re: using offset to move idle tones in audio delta-sigma modulators
Reply #1 - Aug 8th, 2008, 7:45am
Hi Vivek,
I remember the modulator output (binary quantizer, +/-1 levels) for a dc input will generate tones located at:
lx' + k
where x'=(x-Y')/Δ; Y' being the adjacent quantization level to x and Δ the quantizer step size and with l and k being integers.
Further details can be found in "Oversampling methodsfor A/Dand D/A conversion"J. Candy & G.Temes, but unfortunately I do not recall the date for this reference.
See also " Spectral analysis of quantization noise in a single loop sigma delta modulator with dc input" R.M. Gray IEEE. Tran Comm. Jun 1989
Hope this helps
Tosei
Keep it simple
vivkr
Reply #2 - Aug 12th, 2008, 1:02am
Hi Tosei,
Thanks a lot. I will also check the references you mention.
Vivek
