Aug 23rd, 2024, 2:13am
how can I simulate the noise of CDS(Correlated Double Sampling) circuit? (Read 751 times)
daisy
Aug 10th, 2008, 6:55pm
    Hi!
    I want to see the effect of the CDS circuit in decreasing the noise,so I need to simulate the circuit at two different time point--reset and integrating period.As I know,hspice can give the noise result at some certain time point,so how should I simulate the CDS circuit which works at two different time points?
  Thank you!
  daisy
View Profile daisy   IP Logged
Frank Wiedmann
Munich, Germany
Re: how can I simulate the noise of CDS(Correlated Double Sampling) circuit?
Reply #1 - Aug 11th, 2008, 12:41am
See http://www.designers-guide.org/Analysis/sc-filters.pdf. The PNoise analysis of SpectreRF takes into account all the effects. For example, the OPA333 from Texas Instruments was designed with this technique, see http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?isnumber=4014593&arnumber=4014603... and http://focus.ti.com/lit/an/slyt272/slyt272.pdf. I do not know how to do this analysis in HSPICE and if it is possible at all.
daisy
Reply #2 - Aug 11th, 2008, 1:57am
Thank you!I will go to see.
daisy
Frank Wiedmann wrote on Aug 11th, 2008, 12:41am:
