Jul 21st, 2024, 2:16pm
Is 64-bit helpful for Spectre efficiency? (Read 3180 times)
Terence
CAD Lab.
Taiwan, R.O.C.
Aug 13th, 2008, 10:51pm
I am considering to upgrade our Linux from 32 to 64-bit. Our platform is Cadence Virtuoso. Does anyone have experience if 64-bit is helpful for Spectre/SpectreRF efficiency? Thanks!
Terence
bernd
Munich/Germany
Re: Is 64-bit helpful for Spectre efficiency?
Reply #1 - Aug 14th, 2008, 2:57am
With a 32 bit CPU you have a limited memory addressing to 4GB,
which you have not with a 64 bit CPU.
The 64 bit CPU helps you for Spectre/RF if you doing memory  expensive
analysis, like PSS or QPSS.
Don't forget to set the Cadence DFII environment variable 'CDS_AUTO_64BIT'
to your required value.
* bernd
Just another lonesome cad guy
Terence
CAD Lab.
Taiwan, R.O.C.
Reply #2 - Aug 14th, 2008, 6:11pm
Hi Bernd,
Thanks for your reply. Is your overall Cadence Virtuoso platform running smooth with 64-bit? Thanks!!!
Terence
bernd
Munich/Germany
Reply #3 - Aug 18th, 2008, 4:51am
In principle yes.
There are a few exceptions like CDL in/out, the hierarchy editor and
AMS designer which we have issues with 64bit.
For  some you can use the UNIX env. variable with the exclude setting (CDS_AUTO_64BIT=EXCLUDE:<TOOL>)
But this I guess is also dependent on the version of Cadence DFII you use.
* bernd
