Jul 21st, 2024, 4:24pm
Error using cross function of Wavescan (Read 2506 times)
Pavel
Lausanne/Switzerland
Aug 20th, 2008, 2:46am
I try to use cross function (calculator of Wavescan) when doing temperature sweep.
Doesn't work.
The error message appears in log window.
*Error* crossMethod: can't handle crossMethod(nil 2.5 1 "rising" nil nil)
Error message reports that cross function cannot recognize voltage that I specified as 1st argument (as we can see in error message, 1st parameter is nil). Does it mean that this function works only for "true" DC sweeps, but not for temperature?
The syntax of cross function call, generated by calculator, is as follows
cross(VDC("/out") 2.5 1 "rising" nil nil)
Thanks.
Regards.
Pavel.
Pavel
Re: Error using cross function of Wavescan
Reply #1 - Aug 20th, 2008, 3:08am
Resolved.
Right syntax is
cross(VS("/out") 2.5 1 "rising" nil nil)
Regards.
Pavel.
