jbdavid
Most ADC's are pretty useless if they are not clocked.. usually when I see CT in conjunction with ADC, there is the also the term ΔΣ in front of ADC .. is this the case.. if so the CT time part is really an integration stage or two. so a verilog-A model is quite possible. so you need to model the Summing Amp (because you have to add the input with the FEEDBACK DAC) the FEEDBACK DAC, the integration, and the "SLICER" or internal FLASH ADC.. I recommend starting with that flash ADC and the DAC's first.. once you have cut your modeling teeth on those.. you'll be ready to try your hand at the integration stuff..
