Jul 17th, 2024, 6:34pm
Verilog-a modeling under RF simulator (Read 2699 times)
Visjnoe
Aug 19th, 2008, 7:46am
Dear all,
I've been modeling an LNA including non-linearity (Taylor series) + bandwidth limitation (bandpass filter). All is fine in the time-domain (transient HSPICE simulation).
However, when I try to run Harmonic Balance analysis (HSPICERF) it turns out that the simulator won't return accurate results due to some code constructs.
In particulator, I found out that HSPICERF does not handle well the laplace_nd() function. I used this to model the bandpass characteristic of the LNA. Based on the hidden-state discussion/papers on this site, I can see why an RF simulator would not accept the laplace_nd() construct since a filter has state variables which are hidden.
But what is than best practice to model finite bandwidth effects if no laplace_nd() can be used? Of course, we could mimic any filter using passives but I find this not so elegant.
Any feedback welcome!
Peter
Re: Verilog-a modeling under RF simulator
Reply #1 - Aug 19th, 2008, 11:13pm
Actually, the Laplace functions do not represent hidden state. You say that the simulator does not give accurate results. What are the symptoms?
Visjnoe
Reply #2 - Aug 19th, 2008, 11:49pm
Dear Ken,
Ok, that's good to know.
The symtom is as follows: I model the LNA with/without the aforementioned laplace_nd()  and with a 3rd order Taylor series.
In my harmonic balance simulation, I use an input signal with a certain power. Whenever I exclude the filtering from my model, I can see 2nd and 3rd order harmonics at the exact, theoretical power level. Whenever I do include the filtering, the output power levels are all at -300dBm (very low).
I know there is nothing wrong with the filter statement itself, because when I run a conventional SPICE AC analysis, I see the correct bandpass characteristic.
I guess this is an issue I have to take up with the tool vendor (since there does not seem to be a fundamental incompatibility between these code constructs and an RF simulator).
Peter
